Hello Guest it is November 01, 2026, 10:12:22 AM
Author Topic: Press "S" for "rat" Is there a way to slow down the "rat"?  (Read 10963 times)
« on: June 26, 2008, 11:43:44 AM »
Once a cut path is plotted, pressing the "S" key activates the "rat", a small blob that follows the cut paths.  Problem is, on a simple 2d cut like a rectangle, the rat goes so incredibly fast, one cannot tell if the cut path and those of nearby entities is / are correct. is there a keystroke(s) that will control the rat's speed?
Thanks Luv2cCNC
Re: Press "S" for "rat" Is there a way to slow down the "rat"?
« Reply #1 on: June 26, 2008, 02:10:57 PM »
I believe I asked this once before and the answer was no. I would like that too-
 Sorry -   :-\
Offline Glenn
  •  129 129
« Reply #2 on: June 28, 2008, 06:54:24 PM »
Hey luv2c_cnc,
  Thanks for the info on the rat... I didn't even know it existed! I ran mine over a text font, and it seems to work,kind of fast, but how do you stop it once you start it?
I had to hit cont, alt,  delete, just to make the rat stop!
  Just wondering where you got the info, I've read many tutorials I must have glazed over this one ;)
 Thanks, Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
Offline Glenn
  •  129 129
« Reply #3 on: June 28, 2008, 06:56:53 PM »
Hit "s" again, and it stops! ;D
Glenn
