Hello Guest it is August 02, 2026, 02:34:54 PM
Author Topic: I'm ready are you! I/O Questions.  (Read 33783 times)
borrisl
« on: May 25, 2006, 03:04:20 PM »
OK, I've got a GREX pluged in with 6 G201's on it.  The only questions I have is the Digital and Analog Inputs/Outputs.  The documentation is still under development(I hope).  So I'm a little unclear as to the voltages.  Am I correct in that all the I/O is a 3.3V?  So, I need to step down the voltages for all my connections?
It was a hope that I could connect my speed controllers and index units to the GREX.  Is this not possible yet?
Would I be better to drive the 5v ttl signal off the computer power supply (so the drivers are energized only when the computer is on) or the GREX?
I was wiring the Grex into the computer 12V supply as well so I could turn the system on and off with one switch of the computer.  Is this a good thing?
It doesn't mention it, but I've been using sheilded wire for all my low level connections.  Is this overkill?
Looking forward to firing this one off.  2nd Grex is shortly behind this one.
Richard
Re: I'm ready are you! I/O Questions.
« Reply #1 on: May 25, 2006, 03:57:56 PM »
I/O can be done up to 24V but I think you are going to end up doing it at 12V because that is the power supply that you have :)
Brian
www.newfangledsolutions.com
www.machsupport.com
borrisl
« Reply #2 on: May 25, 2006, 10:58:50 PM »
This may seem like a silly question then...
On a E-Stop switch, for example, how would I go about wiring one up.  Would I grap a 5-12 source and from the switch go directly to one of the Digital/analog inputs?
I have several pulse index cards from CNC4PC.  How could I wiring these to the GREX?
Thank you for your response and time.
Richard
« Reply #3 on: May 26, 2006, 08:48:26 AM »
Put a wire from the Ground to an input pin and you will see the LED on the Grex light up :) After that use Port zero and The pin number of  the Grex...
www.machsupport.com
borrisl
« Reply #4 on: May 27, 2006, 01:20:20 PM »
Does this apply to analog and digital inputs?
« Reply #5 on: May 28, 2006, 06:23:58 AM »
I have not done any analog I/O on the Grex :(
www.machsupport.com
borrisl
« Reply #6 on: June 13, 2006, 10:38:24 PM »
In the default Mach4 configuration.  Pins 3 and 2 are in the x,y,z step, direction.  What does this mean?
If I put something on pins 3 and 2 on the digital outputs, what will happen if they are taken by the x,y,z?
Also, I have 6 axis on this machine.  Do I configure those ports on the ports and pins config? If so, what pins are the a,b,c axis?
« Reply #7 on: June 15, 2006, 10:23:30 AM »
I think that the axis just needs to be enabled... So (I think) you can just take the pin numbers out :)
www.machsupport.com
Offline JB
  •  15 15
« Reply #8 on: January 04, 2007, 08:02:32 PM »
borrisl,
 Brian's right on the money there. I e-mailed at directly yesterday and he clued me in that the G100 plugin tells mach to ingnore the motor port and pin assignment, which I've witnessed tonight on my rig. I have 4 G212's that respond no matter what I have done to the "Motor Outputs" tab (if the axis is enabled in the first column anyway), so right now I just put zero's in every slot and still get the same LED light up. You don't even have to have the check box on the Port #1 checked on the "Port Setup and Axis Selection" tab.
 There are a few odd things I've noticed that I would appreciate your feedback on to see if you get the same thing. The DIR LED's on each active axis stay lit, and when I press the X+ or Y+ or Z+ the STEP LED comes on and the DIR LED goes out, but if I press X- or Y- or Z- they both light up and the DIR LED stays lit. I was wondering if this is normal...? (Again, no documentation to follow).
  Other thing is I have a flashing warning next to the wizard's buttons that says alternately "Normal Condition" and "Abnormal Condition" if I have more than the X-axis enabled. This doesn't stop anything, but is sure is annoying. Do you get this as well?
  Heck, right now I would just be grateful to figure out why my steppers won't move.
Take care and best of luck!
John B
Offline JB
  •  15 15
« Reply #9 on: January 04, 2007, 08:03:47 PM »
Sorry,
  Forgot to review before posting... That should have said that I e-mailed Art directly yesterday.
Rgds,
John
