Hello Guest it is November 22, 2026, 06:28:48 PM
Author Topic: Set tool length  (Read 18614 times)
milkof
Set tool length
« on: May 23, 2006, 03:22:40 PM »
Hi, I have a question for you.
I have a sensor for set a tool length but I don’t know how can use it.
Is it possible make a automatism for use it?
There Is a macro?
Could tell me more about?
Regards
 Milko
Re: Set tool length
« Reply #1 on: May 23, 2006, 09:29:57 PM »
There is a video that will tell you one way to do a tool setter... After you have tooled at that you are free to post here and I will help you get it working the way you would like. There are MANY ways to set one up...
Thank you and look forward to getting it working for you
Brian
www.newfangledsolutions.com
www.machsupport.com
milkof
Re: Set tool length
« Reply #2 on: May 24, 2006, 12:00:29 PM »
Brian
Hi I saw a video but i have a problem to understand whit tell.
For me is more simple read.
which is a many wais to set one up.
regards Milko from Italy
Re: Set tool length
« Reply #3 on: May 24, 2006, 01:53:14 PM »
Try this script and please test this in the air.
Zpos = GetDRO(2)
Code ("G31 Z" & Zpos -1.00 & " F10.0") 'Probe  down one unit
Zpos = GetVar(2002) 'Get the point where the probe hit
Code ("G00 Z" & Zpos) 'Rapid to where the probe hit
while Ismoving()
Wend
Call SetDRO(2,0)'Set the Z to zero
 Brian
www.machsupport.com
