Hello Guest it is October 22, 2026, 02:55:42 PM
Author Topic: (2) controllers - setup questions  (Read 12276 times)
« on: June 24, 2008, 05:58:11 PM »
Hello,
I am using a MAXNC 10CL (closed loop) mill (with the the MAXNC controller) under LPT1:
I will be controlling (2) additional steppers (not part of the mill, but part of the milling process) that will be controlled by a different controller under LPT2:
Is this possible with MACH3? I'm gonna need some help with the configuration - anyone interested?  :o
-charlie
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: (2) controllers - setup questions
« Reply #1 on: June 24, 2008, 08:27:55 PM »
Hi, Charlie
Will all help anyway we can, Do you have a second p-port installed. ?
Have you tested it at all.
Others will post.
Chip
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #2 on: June 25, 2008, 11:52:09 AM »
What you seem to be saying is that you are having Mach 3 running a mill on port 1. What you want to do is run another set of kit on port 2, using a different GCode program.
I do not see how you can run multiple versions of mach 3 simultaneously on the same machine.
Mach 3 uses a great deal of the computers processing to generate the various pulses, in strcit time, required for moving the steppers/servos.
What exactly are you asking.
