Hello Guest it is October 22, 2026, 10:24:25 PM
Author Topic: Multi-Hole wizard Change?  (Read 30559 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
« on: June 24, 2008, 10:21:26 AM »
Can you add a Z axis DRO to the Multi-Hole wizard,so if you have holes that need to go to a different depth.And maybe a Reference height for each hole?
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Re: Multi-Hole wizard Change?
« Reply #1 on: June 24, 2008, 06:22:11 PM »
Because of the way the Screen4 program works it would be very difficult to add all those Z DRO values. This is one example of a job that would fit the new Flash screen capability very well.
Suppose the wizard let you open a CSV file generated by a spreadsheet program. Or for that matter even a text editor if you formatted a file with each line contained the 3 values, separated by commas. That would be quiet easy to implement.
