Hello Guest it is November 25, 2026, 02:11:52 AM
Author Topic: Z stepper jerky  (Read 55520 times)
Offline Garyh
  •  19 19
Z stepper jerky
« on: June 23, 2008, 06:46:26 AM »
Hi all, just built a new router with stepper system and Z axis seems to pulsate when running a 3d file. I have tryed all types of motor tuning with
the same result every time? The Z is 1:1 with ball skrew 5mm x1 rev. lift,X-Y have 34 to 72 belt drive and 26t pinion drives,all drives jog around
the table fine. Cuts 2 1/2 fine but when i try 3d files Z seems to run rough. Any help would be great.cheers.
Re: Z stepper jerky
« Reply #1 on: June 24, 2008, 07:09:13 AM »
Are you running straight off the Parallel port? Are you running in Exact stop or Constant velocity more? Can you post your code?
Offline Garyh
  •  19 19
Re: Z stepper jerky
« Reply #2 on: June 24, 2008, 08:06:51 AM »
Hi Brett, Yeah am running of the parallel port, i don't quite know what Exact or Constant velocity mean but will send you this
Gcode file. Its just a simple curved surface file to test machine.i tryed 3 different computers today but all do the same thing .It seems
to be pulsing in Z and X  and not running smooth. Thanks for the reply.
Re: Z stepper jerky
« Reply #3 on: June 24, 2008, 11:38:00 AM »
G61 places your machine in Exact stop mode and G64 places it in CV mode.  There is a G64 in your code which is good.  The code is tiny segments. Have you changed any of the CV settings from dafault Mach?
Offline Garyh
  •  19 19
Re: Z stepper jerky
« Reply #4 on: June 24, 2008, 05:02:22 PM »
Brett , no i havent changed these settings! It looks like if this stepper system wont play the game i think i will change to a
servo system. Cheers Gary.
Offline Garyh
  •  19 19
Re: Z stepper jerky
« Reply #5 on: June 24, 2008, 05:29:24 PM »
Brett, just got a few pic's of my 650-Z router .The steppers are 2550 oz/in showing reduction drives.
Offline Garyh
  •  19 19
Re: Z stepper jerky
« Reply #6 on: June 24, 2008, 05:34:31 PM »
Re: Z stepper jerky
« Reply #7 on: June 24, 2008, 05:50:06 PM »
Thanks Gary, nice looking machine. Any chance you could post a video of it running the code that is giveing you problems? That would help to trouble shoot a lot. Is the path it is running true and just sounds bad or is the z getting out of place?
Offline Garyh
  •  19 19
Re: Z stepper jerky
« Reply #8 on: June 24, 2008, 06:05:15 PM »
Brett, the path it is running is true but Z & X which are both moving at the same time are both struggling to move smooth.
The feed rate then drops right off.
Re: Z stepper jerky
« Reply #9 on: June 24, 2008, 07:48:41 PM »
Gary, please post your xml file and we will have a look.
