Hello Guest it is November 26, 2026, 12:21:39 PM
Author Topic: ook hollanders hier? die verstand van Mach2/3/4 enz hebben?  (Read 16034 times)
Offline swets
  •  52 52
  • www.arjan-swets.com
Ik zoek dus mensen die verstand hebben van Mach2/3/4
en met namen hoe je nu iets maakt  op maat enzo?
ynneb
Re: ook hollanders hier? die verstand van Mach2/3/4 enz hebben?
« Reply #1 on: May 22, 2006, 05:45:47 PM »
Come on Brian, where is your support now :)
Sorry Swets, I dodnt know if we will be able to help you.
Offline swets
  •  52 52
« Reply #2 on: May 23, 2006, 02:39:43 AM »
Alright I try it in english...
is there a tutorial about import a DXF ...
if i make a circle from 20 mm in autocad,... how to import this in MACH2/3 so that the circle from the cnc machine 20 mm  too?
sorry for the bad english....  i do my best....
« Reply #3 on: May 23, 2006, 08:20:25 AM »
You can do it with Lcam but you are going to have to use COMP to get the Dia to the right size. I have to make a video after the bug fixes that I am working on.
www.newfangledsolutions.com
www.machsupport.com
