Hello
Guest
it is
October 02, 2026, 06:08:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Homing all axis Help!!
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Homing all axis Help!! (Read 29182 times)
oskie
29
Re: Homing all axis Help!!
Reply #10 on:
June 24, 2008, 10:42:07 PM »
I also forgot to mention another problem duriing homing. I have a gantry that is driven with two servo's one is slaved onto the other. When I attempt to home the X axis the slave doesn't move, causing a nice twisting action on the gantry arm. I have them slaved together as it moves fine, but not when homing. Any help here would be appriciated.
Logged
Chip
2,055
Gainesville Florida USA
Reply #11 on:
June 25, 2008, 12:01:50 AM »
Hi, Oskie
In config, General Configuration, Is this box checked "Home Slave With Master".
You may need to change the config, Ports & Pins, "Inputs", Active Low State hear for your home/Limit SW's
Chip
Logged
Carnoustie, Scotland
Reply #12 on:
June 25, 2008, 02:08:08 AM »
Yes cables are best to be shielded. Now when your switches get hit does Mach just stop? If you try and home again directly after that do you get an error in the ticker saying that switches already active?
If yes to these then try going to Config then General config and set the Debounnce up to 2000, if it works then try dropping down step at a time until it stops working and then step up slightly again.
Sounds to me like you are homing, the switch gets hit and Mach reverses but the signal from the switch is not great and it bounces, Mach sees the signal go off for a split second so thinks the homing is complete even though the switch has not really shut.
Logged
oskie
29
Reply #13 on:
June 25, 2008, 10:19:33 PM »
I changed the breakout board to an optically isolated board and guess what, my servos are now homing like a champ- Thanks for all the help
Logged
Chip
2,055
Reply #14 on:
June 26, 2008, 01:50:54 AM »
Hi, oskie
Good to hear you got it working.
Chip
Logged
oskie
29
Reply #15 on:
June 26, 2008, 03:29:17 PM »
Thanks, nice to see it finally homing.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
