Hello Guest it is October 21, 2026, 04:04:38 AM
Author Topic: Direction change makes the stepper motor run ruff.  (Read 15358 times)
« on: June 10, 2008, 01:35:07 PM »
I am using the Probotix stepper motor controllers, and after tuning the axis motor, it runs smooth in one direction, but when I change direction, the motor runs ruff or stalls.  What am I doing wrong.
Need help please
Inivator
Offline da21
  •  87 87
    • M-Machine
Re: Direction change makes the stepper motor run ruff.
« Reply #1 on: June 10, 2008, 01:55:10 PM »
as a check disconnect the steppers / servos and turn the ballscrews by hand and see if you notice any binding or they being stiff more  in one direction etc , on the face it sounds as if you have some binding on slides or screws etc  ,or try reducing the tuning a small amount from what would be optimum .
« Reply #2 on: June 10, 2008, 02:10:30 PM »
Also, might want to check your backlash settings.
« Reply #3 on: June 10, 2008, 03:37:17 PM »
Inivator
How are you changing direction ?
If you go from one direction straight to the other using fast jog you will get a screaming sound from the motors and you will loose position
You must let the machine come to a rest before changing.
If you are changing direction in a gcode program you may have the motor acceleration too high again you will loose position.
The bigger/heavier the table the slower the acceleration must be. Time spent here getting it right is time well spent.
HTH
Phil_H
