Hello
Guest
it is
November 22, 2026, 06:38:25 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Stop Button and feed Rate problems
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Stop Button and feed Rate problems (Read 28691 times)
rwlove-lv
23
on:
June 10, 2008, 01:19:56 AM »
I have been running Mach3 for several years now And I have never run into this problem before:
1. After Cycle start is pressed or before Cycle start is pressed the Feed Rate override slide bar is increased has no affect on the actual feed rate it still runs at the same speed as when the first setting is set.
2. The stop button won't do anything but shut down the spindle.
I tried to fix these problems by going into General settings and for the Feed rate problem I thought at first it was the No FRO on queue was checked but it was not. So I reinstalled the software but did not replace the XML or the set file Anyone know how to fix this problem?
Logged
Chaoticone
5,624
Precision Chaos
Re: Stop Button and feed Rate problems
Reply #1 on:
June 10, 2008, 11:55:43 AM »
Are you sure your moveing the FRO slider and not the Rapid over ride slider. The rapid over ride slider has just been added to the 1024 screen set in the past 6 months.
Are you saying that if your running code and press the stop button it just keeps running the code?
Logged
If you could see the things I have in my head, you would be laughing too.
Carnoustie, Scotland
Reply #2 on:
June 10, 2008, 04:26:22 PM »
Sounds like you may need to reinstall Mach over the top of itself.
Logged
rwlove-lv
23
Reply #3 on:
June 10, 2008, 05:17:47 PM »
I reinstalled over the top but used the same .xml file and same .set file. When I hit the Stop button it keeps running code but it does turn off the spindle output.
Logged
Reply #4 on:
June 10, 2008, 05:43:26 PM »
can you attach your xml and maybe we can find a problem.
Logged
rwlove-lv
23
Reply #5 on:
June 10, 2008, 06:03:34 PM »
I will send it tomorrow. I have to go back out to my shop on the other side of town.
Logged
Chaoticone
5,624
Precision Chaos
Reply #6 on:
June 10, 2008, 06:20:10 PM »
Als0, attach your .set file.
Last Edit: June 10, 2008, 06:22:17 PM by Chaoticone
Logged
rwlove-lv
23
Reply #7 on:
June 11, 2008, 09:53:43 AM »
Strange thing happened I changed the Keyboard and the Stop button worked correctly and the feed override worked correctly, but the “Run From Here” doesn’t work now. This I really need.
Thanks, Wayne
Logged
rwlove-lv
23
Reply #8 on:
June 11, 2008, 09:58:42 AM »
Sorry for got to attach files. Send me an email I will respond this forum wont allow me to attach the .set file or the .xml file
rwlee-lv@cox.net
Logged
Reply #9 on:
June 11, 2008, 12:17:49 PM »
The forum will only allow a file to be attached once so you will have to rename them, I suggest that you call them rwlove-lv.xml and rwlove-lv.set
Logged
Print
Pages:
1
2
Go Up
« previous
next »
