Hello Guest it is November 22, 2026, 02:10:01 PM
Author Topic: fast feed  (Read 29701 times)
Re: fast feed
« Reply #10 on: May 20, 2006, 10:35:40 PM »
yes  the slow jog will go faster at 100% . but when i used the fast jog it went faster than the slow jog and i could use the slow jog to machine at the same time use the fast jog(shift + jog ) to move the tool out of the cut faster than the slow jog
Re: fast feed
« Reply #11 on: May 21, 2006, 05:44:28 AM »
marcel
 I am not sure I fully understand what you are meaning but if I understand you are saying that when you have the slow jog DRO set to 100% it is still slower than it used to be. If this is a correct understanding then I think you must have changed your motor tuning or possibly you have reduced your pulse rate from say 45,000 to 25,000.
I am no expert on Mach but my understanding is if the slow jog rate is 100% you cant move any faster as that is what your motors are tuned at.
 One other thing to check is enhanced pulsing is enabled as this may slow things down as well.
Re: fast feed
« Reply #12 on: May 21, 2006, 09:09:28 AM »
thank you i will try it today
marcel
