Hello Guest it is November 22, 2026, 02:09:58 PM
Author Topic: fast feed  (Read 29700 times)
fast feed
« on: May 20, 2006, 01:55:12 PM »
lost my fast feed in mach 3 is there a way to get it back thank you for your time Marcel Beaudry
Re: fast feed
« Reply #1 on: May 20, 2006, 02:55:42 PM »
On Diagnostics page make sure "Fast Jog Rte" is set to 100%
Re: fast feed
« Reply #2 on: May 20, 2006, 03:46:45 PM »
Dear sir
are you using mach 3 turn  in diagnostic i cannot find (fast jog rate)
thank you
Marcel
Re: fast feed
« Reply #3 on: May 20, 2006, 03:52:20 PM »
Yes Mach3, I am using my own screen design but I have not done much to the Diagnostics page yet so it should be there. On my screen it is lower right but I will go and load the standard screen set and see.
Re: fast feed
« Reply #4 on: May 20, 2006, 03:54:18 PM »
Well just loaded the standard screen and its right at the lower right of the Diagnostics screen, you should see the DRO for Fast Jog Rate, just click on it. change to 100 and press enter.
Re: fast feed
« Reply #5 on: May 20, 2006, 03:55:54 PM »
I am an idiot LOL
It is SLOW jog rate not fast ;)
Re: fast feed
« Reply #6 on: May 20, 2006, 04:35:45 PM »
dear sir
all i got on the left side are 4 encoders 3 mpgs  below is the threads diagnostics  below that x dro z dro
Re: fast feed
« Reply #7 on: May 20, 2006, 04:42:34 PM »
lower right is the position on the diags screen see below.
Re: fast feed
« Reply #8 on: May 20, 2006, 09:18:37 PM »
Press the "TAB" Key and you will be able to set it as well   ;D
www.newfangledsolutions.com
www.machsupport.com
Re: fast feed
« Reply #9 on: May 20, 2006, 10:24:22 PM »
my screen does not look like that it looks like, if you look at general discussion and mach3 screen (where they make new screens for mach3 ) and look at the diagnostic sceen you will find what my screen looks like . (sorry for the delay my neibourg invited me for dinner)
Marcel
