Hello Guest it is November 22, 2026, 09:03:13 PM
Author Topic: Stupid question  (Read 12262 times)
Stupid question
« on: June 04, 2008, 06:16:23 AM »
Greetings, Just a silly question.
How many functions can Mach control? As in max number of axis plus spindle control etc? I ask this as I am looking at the possibility of building a combined Lathe / Flatbed Router and can see no way round having less than 7 axis. The material to be machined is wood not metal and the dimensions are not small.
Thanks in advance  :) (and I do have a sense of humour so all comments are accepted). :P
Tim
Re: Stupid question
« Reply #1 on: June 04, 2008, 07:03:41 AM »
6 axis plus spindle
I run a combo Mill/lathe, and I just have a profile for each and just switch between them, using the same axis drives.
if your REALLY need 7 true interpelated axis then mach wont do it for you.
if you need other motors to run more than 6 but the others dont have to be interpelated then you can run them trough an analog board, or PLC with HS pulse driver.
