Hello Guest it is September 29, 2026, 07:52:08 PM
Author Topic: DONT use the "Save and Recall scripts" that I put on this thread!!!!!  (Read 7202 times)
I have removed the post about the Save and Remember scripts that I posted "M1001, and M1002" There was nothing wrong with the scripts themselves, BUT, they did find a "Hole" in the Armor of Mach3 as of version 3.041 and lower!! Brian is aware and is fixing the hole.
NOTE: this script will overload something in Mach, and it will BREAK your VB, and BLUE screen of death your comp........
This problem cause my Mach to not work at all, on any profile. I had to completly delete ALL mach files, remove the driver and redo it all............
Just thought you might want to know.........
Scott
