Hello Guest it is November 18, 2026, 11:17:53 AM
Author Topic: The Forums really work!!  (Read 24412 times)
Jimmy H
« on: May 19, 2006, 08:34:57 AM »
Just a note to all to let you know that I have resolved almost all of my technical startup issues just by reading the forums.
I really appreciate the support level in here.
You guys do a great job!
Jimmy
ynneb
Re: The Forums really work!!
« Reply #1 on: May 19, 2006, 05:06:17 PM »
That was always my hope. Thanks for your feedback :)
« Last Edit: May 19, 2006, 08:11:35 PM by ynneb »
« Reply #2 on: May 19, 2006, 10:55:15 PM »
Great! I hope you found us to be a very positive group! We all work hard to help out all we can. BIG Thank you to everyone!   8)
www.newfangledsolutions.com
www.machsupport.com
vrushali
« Reply #3 on: May 20, 2006, 01:23:24 AM »
hi,
   I would be using mach4 for my desktop cnc machine with
  Stepper controlled  Cnc controller  for 3 /4 axis :(Interfacing with the PC)
  1 No. of parallel and serial ports required?
  2. Analog output for spindle inteface.
  3. Encoder interface for spindle.
  4.Extra I/Os available eg. for turret,robot,logic related to this.(ladder)
  5.limit switches, reference switch details.
  6.Can we use external switches like emergency stop,feed hold, start,reset etc.
  7.Touch screen ver. is availabe?
  8.Is it working with windows XP?
  9.Cam package is availabe with you?
  regards,
  Vrushali A.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #4 on: May 20, 2006, 02:29:58 AM »
The answer to all your questions is, yes it can be done.
Graham.
vrushali
« Reply #5 on: May 20, 2006, 02:32:39 AM »
Thanks a lot for this.But can you tell me how to do this?or can I have details abt this?
regards,
vrushali.
  •  2,785 2,785
« Reply #6 on: May 20, 2006, 02:46:59 AM »
Its not so much the software as the hardware you will need.
The grex will handle most of this but not it all, you may also need Modio and a keyboard emulator depending on how many external switches you want.
If you go to downloads at www.artofcnc.com you can get the mach2 user manual, this gives lots of detail about machine set up.
Once you know how you want to set up your machine, we can then help you with the fiddly bits.
Graham.
« Last Edit: May 20, 2006, 02:58:53 AM by Graham Waterworth »
vrushali
« Reply #7 on: May 20, 2006, 03:13:47 AM »
Thank you u grahm.I wil go through tht.if having doubts wil again trouble u.
regards,
Vrushali
  •  2,785 2,785
« Reply #8 on: May 20, 2006, 03:16:56 AM »
Not a problem.
Graham.
« Reply #9 on: May 20, 2006, 09:14:05 PM »
Also you can use a PLC to run the toolchanger. Mach can talk to the toolchanger over modbus
Hope that helps
Brian
www.machsupport.com
