Hello Guest it is November 03, 2026, 07:59:32 AM
Author Topic: N00b Question about Z axis  (Read 15359 times)
« on: May 19, 2006, 01:44:17 AM »
Very dumb question, but I have read multiable answers so...
I am correct is assuming that most people with gantry style mills setup their Z axis as +10 for top, 0 for part top, and negitive numbers for the cut?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: N00b Question about Z axis
« Reply #1 on: May 19, 2006, 02:36:41 AM »
most mill type machines are set up with the Z axis working minus into the work
Graham.
Offline SignStudio
  •  1 1
  • Mark@SignStudio
    • Sign Studio
« Reply #2 on: May 19, 2006, 04:37:46 AM »
I had thought that as well, but after watching the video's it seems your mill's highest Z point should be set to 0 and you mill down from there. and then you would use an offset, bring the bit down to the surface and zero the Z axis (Not the Mill's Z but the offset Z axis). then if you cut -0.2500 into the surface your cut will come out a quarter inch (if your using inches) into the surface.
This is what i got out of the video's, i might be wrong.
