Hello Guest it is October 24, 2026, 05:52:51 PM
Author Topic: taper threading  (Read 12403 times)
taper threading
« on: May 24, 2008, 05:01:47 PM »
Hi
I tried some taper threading today
I was making a 1.5"-11.5 pipe thread (od)
I used the threading wizard (complex) to write the program
The taper angle was 1' 47" or 1.78'
The program would not run, saying something about an integer in the threading line of
code. ( T1.78)
So I put in a whole number for T ( T2) and the program ran and cut a taper thread, but at 2'
instead of 1.78'
Is this a bug or am I doing something wrong
take care
eddie
Re: taper threading
« Reply #1 on: May 25, 2008, 03:07:10 AM »
what are all of the numbers you are entering in the other DROs as it seems to work fine for me.
Re: taper threading
« Reply #2 on: May 25, 2008, 07:52:10 PM »
Got it working
I was using V1.84 but upgraded to the latest V
But now I have another small problem
see post under OD Arc Wizard
take care
eddie
