Hello Guest it is November 13, 2026, 05:16:16 PM
Author Topic: MPG mode - how to set???  (Read 30355 times)
« on: May 18, 2006, 11:04:26 PM »
OK I need help.  I just added a second parallel port so I could add my MPG and get better performance than with keygrabber.  I think I have it all connected correctly but cannot figure out for the life of me how to get Mach2/3 into MPG mode.  When I toggle the jog modes I can only get incr and continous.  Can someone explain to me what bone-head mistake I'm making here?
Thanks!
+brian
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
Re: MPG mode - how to set???
« Reply #1 on: May 18, 2006, 11:37:24 PM »
The Tab key takes the lathe system into the jog flyout screen, I think it's the same for the mill...?
    Dave.
« Reply #2 on: May 19, 2006, 01:36:15 PM »
Hmmm, yes, I was able to get to this pop out screen but I still cannot get the MPG mode to work.
Here is what happens: I can jog using the arrow keys but when I try to toggle to MPG mode (cntrl-J or pressing the onscreen button) only the INCR and CONT.  leds toggle.  I assume I should be seeing the MPG led turn on.
Also if I try to toggle the MPG axis nothing happens there either.  I did check that the MPG is sending signals by mapping the inputs to some dummy inputs and observing the leds toggle on the diagnostic screen.  So I know the signals are getting to Mach2.
Is there some setting somewhere that I need to set to enable MPG mode?    ???
Thanks.
+brian
« Reply #3 on: May 19, 2006, 03:52:46 PM »
OK, I just tried Mach3 and was able to get it all working.  Still have no idea if how to get the MPG to work in Mach2.  Ah well,  suppose it's time I get serious about using Mach3.
+brian
« Reply #4 on: May 19, 2006, 10:51:39 PM »
Brian
I think you are MUCH better off to be running Mach 3 at this point :)  There are many things in Mach3 that BLOW Mach 2 out of the water ;)
If you have any trouble I am here to help!
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #5 on: May 21, 2006, 05:28:34 PM »
Hi Brian,
Ya, it's time.  I'll be sure to download the latest version of Mach3 and use that from now on.
Thanks!
+brian
« Reply #6 on: December 03, 2014, 12:07:03 AM »
Hey, Brian,
I have the exact same problem in Mach3
here is what happens:
see also my other posting for more information: http://www.machsupport.com/forum/index.php?topic=28531.0
