Hello Guest it is November 13, 2026, 05:09:34 PM
Author Topic: SENSITIVE DRILL PRESS ACCESSORIES  (Read 10389 times)
« on: May 19, 2008, 10:35:22 PM »
You can't make a tool and not have some of the goodies to go along with it. One of the headaches
is how to hold small stuff. This is just an assortment of small things, most of which I made or reground. Two of the handiest
are the pecking base which has a magnetic base and x-y adjustment of it's own and the small tilt table. Nobody makes
a small tilt table which rotates and stays parallel about the base or center line and this one can be set true and dialed in using any side
( took about 16 hours to make ).
