Hello Guest it is November 13, 2026, 08:05:46 PM
Author Topic: "Pulsing to fast" ??  (Read 13809 times)
« on: May 17, 2008, 05:50:47 AM »
Im trying to run the drivertest on a freshly installed 3.041 on win xp. It also a fresh installation of XP, with only mach 3 installed. It keeps saying "Pulsing to fast". This is what it looks like. I also tried the special driver with the same result
How do i solve this problem or is it a problem at all?
Re: "Pulsing to fast" ??
« Reply #1 on: May 17, 2008, 05:58:07 AM »
It certainly is a problem, no way Mach will control your machine with a drive test like that. You should be seeing a fairly straight line going along the centre of the graph with maybe the occasional small spike.
 Does your computer have on board graphics? Or is it a Laptop?
 You could try doing the optimisation steps, you should find details on the downloads page.
« Reply #2 on: May 17, 2008, 06:16:44 AM »
Both. But that hasnt stopped me before:-) This one is faster than the laptop i use for my other cnc machine. It cant be the CPU's fault, its hardly stressed if i look into the performance chart.
Hurray. Though i had already disabled all unnecessary services i remembered something about "Stanrdard pc" setting as mentionen as mentioned in the optimization file. This helped.
To people running into this problem: Remember to set/install xp with the "standard pc" setting (see xp optimization guide in the download area)
