Hello Guest it is November 13, 2026, 09:59:42 PM
Author Topic: Surface grinding?  (Read 101367 times)
Re: Surface grinding?
« Reply #30 on: May 16, 2008, 03:16:23 PM »
Eco,
            Any cam program will work with what you are trying to do. Check out Bobcad there program is very customizable, you only need to put out G-code if you plan on using Mach and you need to control 3 axis and are only going to perform a 2 axis interpulation(x&z) the y will be bumped over at the end of stroke.If all else contact me I believe I can write these for you.
Your cost would be feasible if you were doing the conversion yourself. But this is going to be a bit of work.
I believe any quality grinder will work (although you want gibs not ball ways, its a finish issue) Brown & Sharp and Thompson are a few more SG to look for. We have a small SG at our shop with coolant on it, it is by no means a production grinder. You also want tempurature controled spindle bearings some are air cooled while high end will have refrig units.
« Reply #31 on: May 16, 2008, 03:54:44 PM »
Thanks for the reference... I just checked them out... and talked to them... and their software does NOT do surface grinding.
This all is very frustrating. I've called 5 CAM software companies today and none of them do surface grinding. Is it that there is no market for producing software that writes code for SG? I wonder why.
It certainly may come down to that.
Conversion for what a manual or automatic SG to CNC? Conversion of DXF to g-code?
Thanks... I'll check those brands out.
-- Rich --
vmax549
« Reply #32 on: May 16, 2008, 04:08:15 PM »
Looking at some of the radius involved I believe you would be best served by a belt grinder. The smaller radius will require a small wheel and they do not hold shape as well as large wheels. Belt griders on the otherhand can do small radius with better finish and shape control. BUT there are problems with belts too.(;-) If the reeds are stainless then a mag chuck may be out of the question. Jigs and vacuum table comes to mind here.
All in all I would guess about $ 40-50 K to have a good reed grinder you could depend on. Could Mach do it? It would not be my first choice for this application. I would go with a Seimens grinder controller and high res AC drives. with a bottom res at .00001" .   NOT cheap or for the faint of heart.
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
« Reply #33 on: May 16, 2008, 04:30:53 PM »
Rich,
While they may not specificaly support surface grinding, I can't see how if you can control X,Y and Z from any software you would not be able to adapt that to grinding if you had a machine set up for CNC. It's been a lot of years since I have been around grinders but I recall we used to set them up and they would jog back and forth on their own in the X direction and increment in the Y direction mechanicaly. I can't see other than some of the points made as to wheel wear, spindle cooling and temprature control why one could not take a reasonably accurate grinder, add control motors, limit switches in place of the mechanical stops and control it's motion by software, it's a horizontal milling machine with a grinding wheel instead of a milling cutter! The real problem may be the diameter and width of the wheel in relation to the contour your looking for.
Hope I don't come off snipy, it's not my intention. I have been following this thread since it's got a lot of attention, took a while to find you were making reeds for a concertina, how do you produce the reeds now? I noticed you mentioned hand finishing a while ago in one of your posts, you may allways have to do that operation anyway since each batch may have a slightly different property. To be honest I had never thought about this sort of thing before, now you have me wondering how Honner has made harmonoca's all these years or are they all flat reeds?
Kristin
« Reply #34 on: May 16, 2008, 04:41:09 PM »
Now that's an interesting idea. I've heard that the more modern Italian reed companies use belt grinders but I never knew what they were. You're mention of that got me Googling around. Very interesting. I'll continue to check them out.
-- Rich --
« Reply #35 on: May 16, 2008, 05:02:45 PM »
While they may not specifically support surface grinding, I can't see how if you can control X,Y and Z from any software you would not be able to adapt that to grinding if you had a machine set up for CNC.
That's what I would assume... except that *I'm* not able to do that. I'd have to hire someone to figure it out, set it up for me, and teach me how to make (convert my CAD to) g-code files for it.
I think that's solved. The reed grinders I know either have the spindle tilted at about 2 degrees, or a titled bed, or a beveled wheel... the idea is that only a point of the wheel touches the blank to be ground. Lots of coolant and only very small point grind per pass keeps the steel from loosing it's temper. My friend who makes reeds says that for each pass he moves Y .0005" until the end of the blank and then starts over but down Z .0005" for the next series of passes. My understanding is that this is pretty much what all the concertina makers do (that use a SG).
We don't. Our current models use accordion reeds which we buy in bulk from Italy. We *have* made our own concertina reeds but they've been by entirely hand filing (only for replacement work) and some by working with machine shops to have them produce them (no joy).
Yup. Reeds always need to be hand finished. Even the best made ones in the world from the most sophisticated machines. We'd be very pleased if we'd be able to come within 20 cents (100 cents = 1 semitone) off the machine. Reeds are so sensitive that you could take a reed and it will have a different pitch if put in one part of the instrument or another part - so they have to always be fined tuned anyway. We expect that.
All those reeds have a very sophisticated and exacting multiple curvature. Hohner has an incredible wealth of reedmaking knowledge which they guard extremely well.
-- Rich --
vmax549
« Reply #36 on: May 17, 2008, 09:44:57 AM »
OK now you bring up the 2.5D approach to grinding the reeds. It is an easier approach BUT very "slow" in comparison to the 3D approach. THat process Could be done on a GOOD SG with CNC controll. New machines are available.
ALSO it will require a GOOD cam package to produce reliable program code at that level of interaction. You are moving from a fluid 3d move to a series of simple moves to emulate the same effect. It gets complicated in the code required.
You asked WHY no one likes to work with SG and CNC controllers. Good quality grinding at the micron level require extemely smooth FLUID and precise motion control. Trying to use step drives always will leave a variable at each step it takes in grinding and will effect the surface finish. BEEN there done that. Even Manual grinding with power feed has the same effect there is always a transition mark left at some level. Most 3d grinder controllers have to have extremely good fluid like motion control to produce a quality micron finish. HENCE matched components and HIGH $$$$$.
SO if you are going to have to HAND tune each reed anyway then the extreme griding tolerance is really NOT a factor. Just a good repeatable profile down to a usable tolerance.
In the beginning you mentioned 1000s of reeds but later mentioned  only a few 100 a year. (;-) There is a big difference in what you can get away with machine wise there.
????? Are your reeds stainless steel???  or just tool steel. How do you deal with rust if not stainless ??
« Reply #37 on: May 17, 2008, 10:52:17 AM »
By "that" process do you mean the 2.5D or 3D?
So it sounds like I should be able to get a machine to grind reeds with a 2.5D package? Show me the way!
Yes. I'm hoping that we'll be able to achieve results within 20 cents.
Hmmm... Sorry about the error/confusion. There are 44 pitches of reeds we regularly use (and rarely about 24 higher and lower pitches) and our first years run of concertina-reeded boxes is expected to at least 30 boxes. Each box usually has 2 same-pitch reeds... so 2 reeds x 30 boxes = 60 same-pitch reeds/year. If each blank we grind can be split into 30 reeds that means we'd need 2 blanks x 44 pitches = 88 blanks ground for our first year's production. Just 88 little 4" blanks of steel will yield us 2600 reeds. That's rock bottom minimum. As some of our models have more than two notes of the same pitch (each note has 2 reeds) then more realistically we'd be needing maybe 100 planks = 3000 reeds.
If we were to replace all the accordion reeds we're using in our current models of concertinas with concertina reeds then we'd have to come up with about 350 more ground blanks = 10,500 reeds.
Our reeds are spring steel (not stainless, not tool steel). We don't deal with rust because rust isn't an issue unless one plays constantly in extremely humid conditions (like on a boat on log ocean voyages) in which case you can get concertinas with stainless steel, brass or phosphor bronze reeds (which are very rare). In my 30 years of making and repairing accordions an concertinas I've come across only 2 cases of rusty reeds, and both were due to the boxes being submerged in a basement flood and left to moulder for weeks.
-- Rich --
« Last Edit: May 17, 2008, 10:55:38 AM by ecotectoo »
vmax549
« Reply #38 on: May 17, 2008, 12:02:56 PM »
(;-) You must be in a really dry climate. In FLorida if you leave a piece of ground steel exposed for a few minutes it rusts.
Look on the Web for NEW small CNC surface grinders. they really don't get very small though(;-) Some smaller than others.
« Reply #39 on: May 17, 2008, 02:23:10 PM »
Concertinas are played all over the world though mostly in English-speaking countries like the UK, Ireland, Canada, the USA, South Africa, New Zealand, Australia.... Accordion reeds are made very similarly, and of the same materials as concertina reeds are, and accordions are played pretty much everywhere. Rust isn't much of a problem at all. Even for accordions in Florida.  :-)
-- Rich --
