Hello Guest it is November 19, 2026, 06:58:50 PM
Author Topic: Which cam program?  (Read 9503 times)
Which cam program?
« on: May 13, 2008, 11:04:17 AM »
I have bee experimenting with differing cam programs and am having problems with a particular point.
CUTTER COMPENSATION
I am able to get a shape all the way from a picture into mach3 but cannot find a way to set the cutter compensation so the shape retains it's original size and not undercut it by the tool radius.
As I'm only experimenting I have been using free programs until I find one I'm happy with. I've tried Cambam, Sheetcam & the free Lazycam and this is the only one I've been able to work this out in but it only allows a limited number of code lines to be converted.
So, I'm asking is there a freeware Cam program for me to try that allow more export g-code lines than Lazycam and that is easy to work out how to stipulate a cutter compensation before export?
Something with a decent user guide or advice from a user would be helpful.
Cheers,
Shamus
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Which cam program?
« Reply #1 on: May 15, 2008, 03:01:12 AM »
Go to resources at the top of this page and follow the links, you will find lots of free/low cost solutions there.
Graham.
