Hello Guest it is November 13, 2026, 07:57:20 PM
Author Topic: RhinoCAM for Mach3 and one error  (Read 12699 times)
« on: May 13, 2008, 04:14:31 AM »
I can see a post processor for Mach 1 and 2 but not for Mach 3 - is there or does there need to be a separate file for this?
I have been experimenting which RhinoCAM and using Mach 2 post - seems to work OK with one error on every file:
It's a line in the file "N60 G43 0" which causes an error in Mach3. "Bug unknown motion codeline 5"
I'm a noob at all of this - Is it something I'm doing or a problem with the Mach 2 post file?
I think G43 relates to the offset system??? Do I need to define something there???
Paul.
Re: RhinoCAM for Mach3 and one error
« Reply #1 on: May 14, 2008, 05:10:41 AM »
I found the problem was resolved by removing the "0" from the end. I know understand this command to be the initial tool change command.
Is the problem in the number of the tool or something else.
I can change the post file if I know what needs to be written...
