Hello Guest it is November 07, 2026, 09:18:32 PM
Author Topic: Keyboard translator  (Read 9303 times)
Keyboard translator
« on: May 12, 2008, 07:43:39 AM »
In my case, I use a keyboard emulator to interface my control panel to MACH.  In order to convert some of the keystrokes to MACH friendly versions (so I don't have to substantially modify the standard screen sets), I use Les Newell's "Keygrabber" utility.  It would be helpful to have a "front end" translator built into MACH to accomplish the same function without the use of an external utility.  Just a coulpe of columns of "if MACH receives this stroke -> interpet as that stroke" to allow the ASCII character set to be used based on whatever gadget is creating keystrokes.
Jeff
