Hello Guest it is October 02, 2026, 01:30:27 PM
Author Topic: 5 Axis CAM program For MACH - HELP  (Read 12056 times)
« on: May 09, 2008, 11:24:27 AM »
Does anybody know any other cam program than Mastercam with a simple postprocessor creator to be used for Mach?
Regards
Tiwanacote
« Last Edit: May 09, 2008, 08:39:15 PM by Tiwanacote »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: 5 Axis CAM program For MACH - HELP
« Reply #1 on: May 15, 2008, 03:02:24 AM »
Use a Fanuc 6,11 or 18 post.
Graham.
« Reply #2 on: May 15, 2008, 07:29:38 PM »
Thank you Graham!
« Reply #3 on: July 10, 2008, 04:30:02 PM »
? is Fanuc 6 a program you can just get to use as a post processor?
I am in need of a "lazycam" type program that I can import a dxf wireframe
that has X, Y, and Z movements at all different but simple angles.
Is this something I can use.
Or should I just try to find someone who has a older version of mastercam that
can generate these moves?
Brian
  •  2,785 2,785
« Reply #4 on: July 14, 2008, 10:30:30 AM »
Hi Brian,
DXF is not normally used for 3D, DXF is best for 2D drawings, IGES is for 3D.  Fanuc 6 refers to a g-code format used in Fanuc 6 cnc controls that a CAM system produces code for.
