Hello Guest it is November 19, 2026, 03:36:53 AM
Author Topic: Bizarre Curve Deviations  (Read 27490 times)
rferber
« on: May 17, 2006, 11:15:36 AM »
I've been having some dramatic bizareness on Mach 3 Beta 1.90.36 that wasn't present on 1.90.30 - with some arcs (especially the second G03 in a row), the curve is drawn correctly in the preview (Program Run screen), but the tool doesn't follow the path drawn when making the part (though it knows what it's actually doing - the erroneous path it follows is traced as it actually moved, even though it is at odds with what the intial pre-cut rendering produced). I was careless and didn't do a dry run with floral foam, so it zorched the actual part the first time. I now have a whole library of my normal part code (that worked under Mach 2) that cannot run under Mach 3. This is as bad as the comments-what are comments? bug. I'm rolling back to Mach2 for the present.
Help!
Here is a code chunk that does it (look for the comment midway through):
#40=1   ( UL,UR,LL,LR )
G40
G17
G49
G80
G90
#04=[3/16]
#05=[#04/2    ]
#06=[3/25.4   ]
#08=20
#09=0.2
#52=[ 1/25.4 ]
#53=#52
#55=1
#58=[[#55*2]-1]
F #08
G01 X 0 Y 0 Z #09
#12=FUP[#53/#06]
#13=[#53/#12]
G01 Z 0
G40
G01 Z #09
M3
G01 X [-7.9193+[#05*#58]] Y -0.125
G[41+#55] P #05
G01 X -7.9193 Y -0.125
F [#08/2]
G01 Z [-1*#13]
F #08
G01 X -7.9193 Y 2.1654
G02 X -7.7618 Y 2.3228 R .1575
G01 X -7.2638 Y 2.3228
G02 X -7.1063 Y 2.1654 R .1575
G01 X -7.1063 Y 2.1024
G03 X -6.9488 Y 1.9449 R .1575
G01 X -6.5157 Y 1.9449
G03 X -6.3583 Y 2.1024 R .1575
G01 X -6.3583 Y 2.1654
G02 X -6.2008 Y 2.3228 R .1575
G01 X -5.7677 Y 2.3228
G02 X -5.6102 Y 2.1654 R .1575
G01 X -5.6102 Y 2.1024
G03 X -5.4528 Y 1.9449 R .1575
G01 X -5.0197 Y 1.9449
G03 X -4.8622 Y 2.1024 R .1575
G01 X -4.8622 Y 2.1654
G02 X -4.7047 Y 2.3228 R .1575
G01 X -4.2717 Y 2.3228
G02 X -4.1142 Y 2.1654 R .1575
G01 X -4.1142 Y 2.1024
( this next line renders correctly before execution, but the tool deviates here)
G03 X -3.9566 Y 1.9450 R .1575
G01 X -3.5236 Y 1.9449
G03 X -3.3661 Y 2.1024 R .1575
G01 X -3.3661 Y 3.3465
G02 X -3.2087 Y 3.5039 R .1575
G01 X -2.7756 Y 3.5039
G02 X -2.6181 Y 3.3465 R .1575
G01 X -2.6181 Y 2.1024
G03 X -2.4606 Y 1.9449 R .1575
G01 X -2.0276 Y 1.9449
G03 X -1.8701 Y 2.1024 R .1575
G01 X -1.8701 Y 2.1654
G02 X -1.7126 Y 2.3228 R .1575
G01 X -1.2795 Y 2.3228
G02 X -1.122 Y 2.1654 R .1575
G01 X -1.122 Y 2.1024
G03 X -.9646 Y 1.9449 R .1575
G01 X -.5315 Y 1.9449
G03 X -.374 Y 2.1024 R .1575
G01 X -.374 Y 2.1654
G02 X -.2165 Y 2.3228 R .1575
G01 X .2165 Y 2.3228
G40
G01 Z #09
G01 X 0 Y 0 Z #09
M30
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Bizarre Curve Deviations
« Reply #1 on: May 17, 2006, 04:40:34 PM »
I have checked your code and can find nothing wrong with it,  I think this is one for Art but he is at the CNC-workshop meeting.
Graham.
rferber
« Reply #2 on: May 17, 2006, 06:13:34 PM »
Thanks! Nothing beats a second set of eyes willing to look code over. I hate to bother Art with noise. -- Rob
rferber
« Reply #3 on: May 24, 2006, 11:13:35 AM »
Thanks!. Art has addressed this in 1.90.38, looks good.
