Hello
Guest
it is
November 13, 2026, 08:12:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Running macro and testing them
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: Running macro and testing them (Read 82915 times)
CJEls
69
Re: Running macro and testing them
Reply #30 on:
May 10, 2008, 01:26:12 PM »
Hood the turret reverses to lock.You can hear the turret going past the locking pointand then it must reverse. The OEM triggers is working I tested it in a brisn brogram.
CJEls
69
Reply #31 on:
May 10, 2008, 01:35:27 PM »
Hood the previous reply should have been brain.I tested it with a brain program and with that it is working (the OEM TRIg).
Carnoustie, Scotland
Reply #32 on:
May 10, 2008, 01:43:19 PM »
Ok if it reverses I dont see that in the macro, will look again though.
What kind of motor is on the turret? What does OutPut4 actually switch on and off?
CJEls
69
Reply #33 on:
May 10, 2008, 01:50:16 PM »
Hood output4 drives a relay to turn the turret.When this relay falls away another relay comes in at a lower voltage and reverses the turret. This is hard wired.
CJEls
69
Reply #34 on:
May 10, 2008, 01:52:46 PM »
I have disconnected the revers relay just to see if the relay was the problem.
Reply #35 on:
May 10, 2008, 01:52:57 PM »
OK that explains why its not in the macro, so I am presuming there must be some sort of stop pin or ratchet that is also released when output 4 is active and dropped when its not?
CJEls
69
Reply #36 on:
May 10, 2008, 01:56:08 PM »
It is a ratched type turret.When it reverses it locks the turret.
Reply #37 on:
May 10, 2008, 01:59:16 PM »
OK, thats good, I have an understanding of how it works now.
I am trying out a few things in the macro, will post back if I find anything, wish Graham would jump in with the answer
CJEls
69
Reply #38 on:
May 10, 2008, 02:01:23 PM »
Hood I even tried to Use iunput 1 to4 in the place o OEMtrigger1 to4 with the same result no output.
Reply #39 on:
May 10, 2008, 02:28:13 PM »
You would have to set the macro to look for the Inputs rather than OEM Triggers if you are going to do that.
I am going to try something else but just cant get why its not working, I can get the output operating but the triggers are not stopping it, wish I was more knowledgeable in VB
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
