Hello Guest it is November 13, 2026, 09:47:31 AM
Author Topic: Problem with dowload version 3.41  (Read 19982 times)
« on: May 04, 2008, 05:03:16 PM »
Hello to all,
well I went and upgraded from version 3.37 to 3.41 and the display for the tool path don't work no more,the Z axis don't show going up and down,and the crossair and tool paths don't display any more,also I have a plug in from CandCNC for a pendant and the plug in don't work any more also.
I know , just go back to and earlier version,well that didn't work either. Any ideas?
Thank You ,Marco.
Re: Problem with dowload version 3.41
« Reply #1 on: May 04, 2008, 06:38:46 PM »
Try going back to one of the backup xml's.
« Reply #2 on: May 04, 2008, 06:41:51 PM »
Hello Hood,
I try that and did not fix the problem.
Thank You for the help,Marco.
« Reply #3 on: May 04, 2008, 06:53:29 PM »
Make sure the plugin is in the plugins folder, if not re download it and install it again. For your toolpath problems have a look at the Config menu then Toolpath and see if you have the boxes checked for the crosshairs etc.
« Reply #4 on: May 04, 2008, 07:24:32 PM »
Hello Hood,
here is a picture of the error for the plug in
Marco.
« Reply #5 on: May 04, 2008, 07:27:17 PM »
Tried reinstalling the plugin?
« Reply #6 on: May 04, 2008, 07:27:30 PM »
Hello Hood,
the display is fix now,all of the boxes where unchecked,weird.
Now the only part left is the plug in
« Reply #7 on: May 04, 2008, 07:28:35 PM »
Hello Hood,
yes and got the error above.
Marco.
« Reply #8 on: May 04, 2008, 07:34:25 PM »
Sorry dont know about the plugin, I will see if Brian knows.
« Reply #9 on: May 04, 2008, 11:43:26 PM »
I think they have built the plugin for an older Rev of Mach3... I have not changed the pointers so it should be fine..
The problem is in there code so install the release rev and tell me if you have the problem please
Brian
www.newfangledsolutions.com
www.machsupport.com
