Hello Guest it is November 13, 2026, 04:59:19 PM
Author Topic: External buttons  (Read 14089 times)
External buttons
« on: April 27, 2008, 02:34:43 AM »
 Who can explain me how to find a pin for connecting an external button "cycle start" and an external button "go to Z" ?
Thank you.
regards
Anthony
Re: External buttons
« Reply #1 on: April 27, 2008, 03:04:57 AM »
You connect any spare input pin you have. You then go to Ports and Pins and Inputs and set up one of the OEM triggers to the pin you have chosen. The last step is to go to the Config menu then to system Hotkeys and enter the OEM code for the function into the box for the OEM trigger you have chosen. From memory 1000 is the OEM for cycle start and I think 1017 is for Go to Zeros. I will post an xml with all the known OEM codes in it in a sticky at the top of the forum in a few mins once I find it on my drive.
« Reply #2 on: April 27, 2008, 04:54:07 AM »
Hi Hood,
 thank you for your help, i will wait your next good news.
best regards
Anthony
« Reply #3 on: April 27, 2008, 06:13:03 AM »
Its there Anthony, look at the top of the list, you will see the sticky.
