Hello Guest it is October 14, 2026, 05:51:37 AM
Author Topic: Z-Axis Home position - up or down?  (Read 21247 times)
« on: April 22, 2008, 04:34:29 AM »
Should the Z-Axis Home position be up or down? I have home-built CNC router.
Re: Z-Axis Home position - up or down?
« Reply #1 on: April 22, 2008, 07:12:28 AM »
depends, usually it is up to clear your work as you dont want it to move down into your work while referencing.
 Usually the highest off the work that your Z can move is machine zero and that means all z moves are in a negative direction with machine coordinates. Obviously when youhave work offsets you can have + and - z moves but in relation to machine coordinates they will all be negative moves.
« Reply #2 on: April 22, 2008, 02:58:12 PM »
Let's say that the home position on my CNC machine is 0,0,4 with the Z-Axis carriage moved up. When I run Cut2D program to create signs, etc, and load G-Code into Mach3 program, what should I do so that the CNC machine routs letters 0.25 inch deep on 0.75 inch piece of wood placed on the machine's base?
« Reply #3 on: April 22, 2008, 03:26:10 PM »
OK the normal way is home your machine, the zero position in machine coordinates for Z would be the highest point and the lowest would be Z-*(* being your amount of Z travel)
. When you want to machine something your code would have z0 as the top of the material and z-0.25 would be your depth of cut. To get that to work you would jog down to your material and zero the Z DRO, this makes a work offset of the surface of your material as zero and z-0.25 would be a cut of 1/4" into the material.
