Hello Guest it is October 20, 2026, 06:02:28 PM
Author Topic: Ref all Home  (Read 12809 times)
Ref all Home
« on: April 20, 2008, 02:00:14 AM »
When I ref all home, the x and y axis move to the home switch a back off a small distance which is noticeable.
The Z axis moves to the home switch but there is no visible back off.
Is this normal?
Thanks Mike
Re: Ref all Home
« Reply #1 on: April 20, 2008, 02:24:50 AM »
What is your  Z axis Steps per unit set to? Is your Z Axis on ful step or half step by any chance?
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Ref all Home
« Reply #2 on: April 20, 2008, 03:24:35 AM »
Also have a look at the Z DRO - does it move. It could be you have backlash in your Z axis, and the movement is taken up by this. Cut down the speed of the homing, and this will make it clear what moves where - it might be better to cut of the auto-zero as well while you check it out.
