Hello Guest it is November 23, 2026, 09:07:30 PM
Author Topic: beefing up a G320  (Read 16733 times)
Offline comet
  •  338 338
beefing up a G320
« on: April 19, 2008, 12:21:28 PM »
  Is it possible,on the g320, to remove the power mosfets and replace them with remotely mounted 200 volt ones.
to run bigger motors? Assuming they are mosfets!
   Tony
Offline comet
  •  338 338
Re: beefing up a G320
« Reply #2 on: April 23, 2008, 12:46:37 PM »
Couldnt find anything there.I really would like to upgrade my anilam equiped mill to mach3 especially as I have a license!
The motors are rated at 200 volt not sure what there actually being fed with though I would guess 110v. They are 30 amp dc brushed.
« Reply #3 on: April 23, 2008, 06:02:10 PM »
Hi, Try posting this question on the CNC Zone forum under Gecko Drives. Mariss Freimanis is the man you need to answer this one.
Regards
John
« Reply #4 on: April 23, 2008, 08:37:18 PM »
I put the link to the geckodrive yahoo group up for you to ask there, you'll get a quicker answer.  Or post on the gecko board on cnczone.  Either one will probably net a quicker answer since this is a Mach forum, not a Gecko Drives forum.
Monte
« Reply #5 on: April 23, 2008, 08:49:35 PM »
The simple answer is no.  There is a LOT more to controlling a more powerful motor then just bigger fets.
Read this thread and you will get a better idea of what is involved in controlling a simple DC motor as a servo:
http://www.cnczone.com/forums/showthread.php?t=14217
