Hello Guest it is November 13, 2026, 09:39:19 AM
Author Topic: I'm really desperate and will pay $2 million dollars for the answer  (Read 33951 times)
Re: I'm really desperate and will pay $2 million dollars for the answer
« Reply #10 on: April 21, 2008, 07:56:44 AM »
Thanks Hood
Just tried it, connected motor it says Rdy
Motor doesn't start, no power to the terminals the only button that seemed to work was the M button the display said 50 when pressed.
Phil_H
« Reply #11 on: April 21, 2008, 09:16:11 AM »
OK that makes sense, M will be for Mode, ie all of the parameters. Maybe going up and down will let you see a parameter that needs setting but without a list I doubt you wont know what they mean. Maybe if you download a manual for one of their other VFDs the parameters will be similar, I found one yesterday for a MD2005 or something like that. Could possibly be that the external buttons have been disabled because they had a remote pot on it for speed control and a switch for Fwd/Rev. Again without knowing the terminals or the parameters to select it will be difficult, but maybe there is some indication of where a pot would connect, moulded into the terminal block.
« Reply #12 on: April 21, 2008, 10:23:24 AM »
Thanks Hood and Jim for the help.
I have now got a manual. ;D ;D ;D
But the inverter is not powerful enough  :'( :'( :'(
But i have been looking and have found a motor inverter package and hopefully i will get it Tuesday
Phil_H
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #13 on: April 29, 2008, 03:13:25 AM »
Phil - You are not another Scot - or even Welsh - are you  ???
« Reply #14 on: April 29, 2008, 06:02:49 AM »
What are you implying Jim  ::)
Phil_H
Offline jimpinder
  •  1,232 1,232
« Reply #15 on: April 29, 2008, 07:02:15 AM »
Phil - you will have to excuse Hood and me.
Actually the inverter you have looks like a neat unit - and you say you have a manual. What sort of power does it give out - is it OK for running a drill press - or even a cross slide mounted drill of some sort.
« Reply #16 on: April 29, 2008, 10:34:03 AM »
Hi Jim
Yes it is a nice unit. the rating is actually shown on one of the pictures, 11amp input 240V, 4.3amp output 440V
It is working i didn't remember that i had removed a switch which connects to two of the terminal strips. That is why it didn't work. ::)
I bought it with an pantograph engraver.
Are you going to make me an offer for it as i was going to put it on that well known auction site.
Phil_H
Offline jimpinder
  •  1,232 1,232
« Reply #17 on: April 30, 2008, 02:53:09 AM »
I've nothing to run it with (yet).
Now you have the manual - can it be connected to computer control.
If so give me a price to think about
