Hello Guest it is November 23, 2026, 05:24:12 AM
Author Topic: softlimits update  (Read 8454 times)
softlimits update
« on: April 16, 2008, 12:59:05 PM »
Hi
We are writing a script code to update the softlimit value in Z axis. We are using the command: Setoemdro(158, value).
We are surprised we can move the axis over this limit, Mach3 is using the previous softlimit value and it doesn´t obbey the new value we have programmed.
We also are surprised we open the sofltimit dialog and it is with the value we have already programmed, when we close the dialog Mach3 then runs according to the softlimit value we have programmed.
It seems as if the softlimit value programmed with the oemdro(158) command is not inmediately reading by mach3.
How can we solve this hassle?
Thanks in advance,
Konektada
