Hello Guest it is September 05, 2026, 11:46:55 PM
Author Topic: help  (Read 16035 times)
help
« on: April 16, 2008, 12:52:57 PM »
hi i have an error message on my mach 3 mill that says abnormal condition when i move my poiter over it it reads g90/g91 does anybody no what that is thanks bn
Re: help
« Reply #1 on: April 16, 2008, 01:13:38 PM »
Are you loading code or is it just as you start Mach? Try putting G91 in the MDI line and pressing enter.
Re: help
« Reply #2 on: April 16, 2008, 08:43:42 PM »
it is there when i start i does not effect movement i can load g code and it does fine it is always flashing i tried typing g90 g91 in mdi and nothing thanks ben
Re: help
« Reply #3 on: April 17, 2008, 01:05:12 AM »
Please attach your xml so we can have a look. You will find your xml in the Mach3 folder, you will have to rename it before the forum will accept it as an attachment.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: help
« Reply #4 on: April 17, 2008, 08:25:29 PM »
Hi, Ben
If everything is working and operating fine, You must have changed or run some G-code that set Mach or Left Mach in a different Normal Condition/Abnormal Condition.
I don't have a list of these item's, But it can be as simple as running some G-code that leaves Mach in a G91 inc. mode,
If your Normal Condition on startup is G90 abs. mode, The button will flash green/yellow.
With the Msg you have, A g90 or g91 on the MDI line should re-set/fix it.
To reset the  Normal Condition/Abnormal Condition, green/yellow flashing back to Green, Just Double-Click on the Button and say yes to the Prompt Msg.
Thanks, Chip
Re: help
« Reply #5 on: April 20, 2008, 07:44:12 PM »
thanks for the help. everything is working even when it flashing. i tried double clicking and that works. i could not figure out how to post my xml. the only thing i found was xml. backup but windows would not let me save it on cd-r.
Offline Chip
  •  2,055 2,055
Re: help
« Reply #6 on: April 20, 2008, 09:21:03 PM »
Hi, Ben
Sounds like you sorta got it sorted out.
Chip
