Hello Guest it is October 21, 2026, 12:12:20 AM
Author Topic: Manual Tool Change  (Read 15634 times)
Manual Tool Change
« on: April 16, 2008, 06:21:50 AM »
I hope I am not going over old ground.
I would like to experiment with manual tool changes on my router.
ie. the program calls a macro to allow the spindle to be moved to a set position so that I can change the cutter.   Then the tool height needs to be sensed by touching a known point that tells mach3 to calculate the z offset to match the correct tool height . The spindle should then move to the return point in the program to continue the cut file.
Is this an inbuilt feature of mach3 ( "settings"' panel?)
How can it be configured?
Bruce
Re: Manual Tool Change
« Reply #1 on: April 16, 2008, 09:36:12 AM »
I don't have a ton of experience with this and it has been a few versions ago since I messed around with it but...
There is a set of radio buttons on the General config page that tells Mach what to do when it sees an M6 command that you add to your G-Code when you want the tool to change.  Select the 'Stop Spindle and wait'.  I think you also have to make sure that on the settings screen that the 'Ignore tool change button is not selected/lit.
When you run your code, Mach will stop when it sees an M6 command and then wait for you to do your change & rezero when you hit the cycle start button, I think the machine will bring up a dialog box and tell you it wants to reposition itself to continue the cut.
It's pretty easy/intuitive once you have the config/settings stuff out of the way.  Try it first without chucking up any cutters to be safe though!
HTH,
Sid
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #2 on: April 16, 2008, 11:13:29 AM »
If you watch the Video Tutorials there is a program on "Scripting" which covers this exact problem.
The M6 script can be altered to do precisely what you want - in other words - move to a preset location and wait til you have reset the tool. You can jog the tool up and down onto a plate or measure or what ever, change the z axis offset and resume.
The script is in Visual Basic and is fairly easy to learn - if you know any of the programming languages, and the scripts themselves can write GCode to move the mill directly.
I have this on my lathe (slightly different command but) - the tool away from the work, I change the tool and the tool number changes which brings into effect the new tool offsets. I have a quick change holder, so my tools and offsets are all preset - but that is something for you to think of in the future.
« Last Edit: April 16, 2008, 11:16:38 AM by jimpinder »
« Reply #3 on: April 16, 2008, 07:23:14 PM »
Thanks fellows, I will delve further.
Bruce
