Hello Guest it is November 23, 2026, 09:07:35 PM
Author Topic: increase the feed (accelerando)  (Read 14459 times)
Offline ayhan
  •  12 12
« on: April 16, 2008, 02:08:10 AM »
Hello everyone,
Is there any G code to increase the feed in the same line.?
For example X will go 20mm . will start as F50 while it finish should be reached F100
as accelerando
Ayhan
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: increase the feed (accelerando)
« Reply #1 on: April 16, 2008, 02:29:40 AM »
I thought I had replied to this yesterday - I don't think so - but why do you need it.
Mach3 will respond to CSS - Constant surface speed - where you are taking a cut across the face of work on a lathe - and the SPINDLE will accelerate to keep the speed pf the work past the tool constant. I suppose, but have not tried it, that this would also be the same cutting a taper shape. For this, though, the spindle speed must be controlled by Mach3.
The problem is the GCode can only have one instruction (of each type) on a line - so one F instruction is all you can have. You could split the line into say 5 lines, and increse the Feed in each one, if you have Constant Velocity on the effect would not be too bad. - BUT why do you need it.
Offline ayhan
  •  12 12
« Reply #2 on: April 16, 2008, 03:18:58 AM »
Dear Jimpinder ,
Thank you for your reply,
I think I will split the line it is better.
I have tig torch instead of spindle. In the begining of work, work piece is cold (no problem) , but later it gets warmer so torch burn the piece. There is also cold wire feeder in the same line.
X-Y-Z (B works as wire feeder) all of them have interpolation.so,so
I will split the feed in 5-10 lines, try again.
Thanks a lot again.
Ayhan Caglar
Offline jimpinder
  •  1,232 1,232
« Reply #3 on: April 16, 2008, 12:30:08 PM »
Now I understand - make sure you are set on Constant Velocity for this.
