Hello Guest it is August 26, 2026, 06:35:55 PM
Poll
kit do not function
problem
0 (0%)
problem
0 (0%)
Total Members Voted: 0
Author Topic: big problem mach3 cnc  (Read 33664 times)
« on: April 13, 2008, 07:03:58 AM »
Hello
I am French, excuse me for my language.
I buy this kit: http://www.probotix.com/index.php?view=product&product_id=45]http://www.probotix.com/index.php?view=product&product_id=45
(4 kit stepper motor 400 oz / inch)
I'm plugged the card on the parallel port.
I have Mach3.
I configured mach3: http://www.probotix.com/cnc_downloads/
And when I press the keys, stepper not running!!!
The stepper motor work because when I plug in food, motor are: Bzzzzzz .... And when I want to turn the axis in hand, it stops.
with USB, but it does not work.
Please help me
thank you
« Last Edit: April 13, 2008, 08:39:40 AM by jayls »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: big problem mach3 cnc
« Reply #1 on: April 13, 2008, 11:29:52 AM »
Hi, Jayls
Tell us about your computer, Have you checked Port address and made sure it set to the proper address, 0378 is standard, But your's may be different.
See pic. below.
Hope this Helps, Chip
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: April 13, 2008, 11:41:44 AM »
Hi Jayls
Hi Chip - I think the USB is only being used on this system for +5V logic supply. According to the piccies Jayls hasn't connected the parallel port.
Hi Jayls
employez tous les deux, LPT1 et USB
USB c'est pour +5V
LPT1 c'est pour commande les moteurs
Ian
Offline Chip
  •  2,055 2,055
« Reply #3 on: April 13, 2008, 12:11:37 PM »
Hi, Ian
His comment "I'm plugged the card on the parallel port", True the Pic doesn't show it.
Gotta-Start-Somewhere, Could be it.
Thanks, Chip
Ooop's, Left out the Welcome-Aboard "Stirling" !!
Chip
« Last Edit: April 13, 2008, 01:29:02 PM by Chip »
« Reply #4 on: April 13, 2008, 12:18:15 PM »
hi
thanks for your answers!!!!
I'm connect LPT1 and  USB?
I will try.
very thanks
Offline stirling
  •  2,188 2,188
  • UK
« Reply #5 on: April 13, 2008, 12:57:05 PM »
Hi Chip - oops - missed that, sorry - too busy looking at piccys and not reading ;D.
Ian
A belated - thanks Chip.
« Last Edit: April 15, 2008, 08:00:31 AM by stirling »
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #6 on: April 14, 2008, 07:54:21 AM »
Stirling - You're not French are you - excellent reply
« Reply #7 on: April 14, 2008, 04:07:54 PM »
I have the same problem with a new control box with Gecko drives and IBM computer.
All the control box components work properly with a computer from another machine that is known to work with Mach. I have tried two different IBM computers and only get a high pitched whine from the steppers. I have seen this problem posted here and on the Geckodrive Yahoo group, but with no solution.
« Reply #8 on: April 14, 2008, 05:18:08 PM »
Have you run the drive test to see what it looks like?
« Reply #9 on: April 14, 2008, 05:37:33 PM »
Yes, I have run the driver test. There is nothing that looks unusual. The signals do get to the motors, but the motors do not respond with movement.
