Hello Guest it is October 23, 2026, 08:58:40 PM
Author Topic: square threads  (Read 23513 times)
square threads
« on: May 12, 2006, 07:51:47 PM »
how do you program the thread wizzard to make square threads
Re: square threads
« Reply #1 on: May 12, 2006, 08:11:51 PM »
Change the infeed angle to zero and you should be good to go :)
www.newfangledsolutions.com
www.machsupport.com
Re: square threads
« Reply #2 on: May 12, 2006, 08:14:42 PM »
thanks you
Marcel
Re: square threads
« Reply #3 on: May 12, 2006, 08:16:24 PM »
If you have any trouble I will be up and about for a few more hours  ;D
www.machsupport.com
Re: square threads
« Reply #4 on: May 12, 2006, 08:34:26 PM »
Dear sir
thank you for your quick reply what is the difference in external threads and internal execution wise
Marcel
Re: square threads
« Reply #5 on: May 12, 2006, 08:42:55 PM »
External threads will cut into the part fron out outside. So the rapid moves will pull out in the +X Direction and cutdepths will go more negitive the deeper the thread is cut. The internal threads will rapid back in the -X direction and will advance the cut in the +x direction. I think that is what you were asking ... and to get the wizard to cut an internal thread you just have to give a smaller start dia and a larger end dia.
is that any help?
Brian
www.machsupport.com
Re: square threads
« Reply #6 on: May 12, 2006, 08:52:16 PM »
yes this is what i wanted i will try it tomorrow (wife in bed lathe in the basement under the bedroom if you want me to give you a reply from the same adress , ill try it tomorrow)
Re: square threads
« Reply #7 on: May 13, 2006, 01:08:11 PM »
thank you Mr Barker  worked like a charm
Re: square threads
« Reply #8 on: May 13, 2006, 08:46:40 PM »
Great I wrote the threading code a LONG time ago and I think I know how it works now ;)
www.machsupport.com
