Hello Guest it is November 19, 2026, 05:56:48 PM
Author Topic: Simple G-Code Loop Question  (Read 25340 times)
« on: April 04, 2008, 10:31:13 AM »
With Mach3, i have a problem with looping. here it's :
G00 X20
M98 P1
L 10
G00   Z-2.5
G00   Y29
G00   X8
G00   Z-5
G00   Y0
G00   Z0
G00   X0
M99
M30
It gaves loop errors, and it loops forever...
In fact all i want is to proceed with 10 loops for the following basic g-code :
G00   X20
---- loop starts here ----
G00   Z-2.5
G00   Y29
G00   X8
G00   Z-5
G00   Y0
G00   Z0
G00   X0
---- loop ends here ----
Thanks for any help...
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Simple G-Code Loop Question
« Reply #1 on: April 04, 2008, 11:10:38 AM »
You could do it like this :-
O0001
G00   X20
M98 P2 L10 (call sub 10 times)
M30
O0002
G00   Z-2.5
G00   Y29
G00   X8
G00   Z-5
G00   Y0
G00   Z0
G00   X0
M99
Graham.
« Reply #2 on: April 21, 2008, 08:57:43 AM »
Thanks Graham,
It worked, in fact i found similar gcode from forum then both are successfull, the thing now i'm looking for is a "counter" for processing part number.
Regards
vmax549
« Reply #3 on: April 21, 2008, 01:01:36 PM »
IF you are looking for a loop counter then MACH has one there is a hidden DRO that reports the number of loops processed. I will try to find the DRO number for you, then you can place the dro on the screen and have a counter.
NOTE:  The DRO# is 222     It is basically a nest counter. It sees the total loop number then subtracts one each pass.  You may have to add a G04p0 to the last line of the sub before the g99 call to keep the dro current to the loop.
« Last Edit: April 21, 2008, 01:16:53 PM by vmax549 »
