Hello Guest it is November 23, 2026, 04:10:50 AM
Author Topic: Arrow Keys +Ctrl +Alt +Shift  (Read 11634 times)
« on: April 04, 2008, 10:05:39 AM »
In a previous version of Mach 3 the combination of any Arrow Keys + Ctrl or Alt or Shift was giving a different behavior on jogging  speed (smaller/greater speed or single jog step )
On newer versions this is not working anymore.
It is a matter of xml config file or this functionality has been obsoleted ?
I have tried a combination of an xml config from an old exe to a newer exe version but without clear results.
Daniel
Re: Arrow Keys +Ctrl +Alt +Shift
« Reply #1 on: April 04, 2008, 10:39:06 AM »
If you have the slow jog rate set to a lower % the when jogging it will go at that rate, if you press the shift and Jog it will go at full rapids (100%)
Sounds like you have the slow jog rate at 100% but on previous versions you had it set lower.
