Hello Guest it is November 01, 2026, 10:03:07 AM
Author Topic: 3d solids in lcam  (Read 14018 times)
3d solids in lcam
« on: March 31, 2008, 03:28:14 PM »
Hi
I have Solidworks at work, can you use the solids in lcam.
Clive
Re: 3d solids in lcam
« Reply #1 on: March 31, 2008, 08:54:11 PM »
You'd have to do a drawing of the model then save that as a dxf to import into LazyCam-
« Reply #2 on: April 01, 2008, 05:41:16 AM »
I take it you mean go backwards to a 2D drawing.
I think I am right in saying you can export a 3D DXF file.
regards
Clive
« Reply #3 on: April 01, 2008, 03:11:55 PM »
I see, I think I misunderstood you. I don't believe LazyCam can handle 3D images, only  steps (Layers).
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: April 01, 2008, 07:22:45 PM »
Hi, Clive
LazyCam is for converting 2d dxf into 2.5d g-code format not true 3d, Pocketing, Offsetting, Hole drilling and such, It's Lazy.
Mach3 will load 3d G-code generated by a cad-cam package with the proper post, Have you checked if theres a post for Mach3.
It uses allot of Funic/standard/common type g-code.
Hears a BobCad posted G-code 3d item.
Thanks, Chip
« Reply #5 on: April 03, 2008, 08:32:27 AM »
Thanks for the replies.
I think the 2.5D comment puts it in perspective.
Mine is a hobby scenario so I dont really need anything cleverer.
Thanks again
Clive
