Hello
Guest
it is
October 24, 2026, 07:58:02 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Help!!!!!
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Help!!!!! (Read 38052 times)
TT350
113
Help!!!!!
on:
March 28, 2008, 11:55:45 PM »
This is some weird stuff guys, After this was cut I checked my X/Y position and found that my X was out over an inch.
This sould been a round hole. I was cutting this on my Tormach.
Take a look at the code and see if any thing is wrong.
Chris
Last Edit: March 30, 2008, 05:24:48 AM by Graham Waterworth
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Help!!!!!
Reply #1 on:
March 30, 2008, 05:23:10 AM »
What did you use to create the code and the drawing?
The code is very long for such a simple job.
Graham.
Logged
TT350
113
Re: Help!!!!!
Reply #2 on:
March 30, 2008, 09:40:42 AM »
Visual mill 5.0
Logged
TT350
113
Re: Help!!!!!
Reply #3 on:
March 30, 2008, 10:50:44 AM »
I cut a part about 6 mouths ago where it cut an arc and the arc was made up of lots of little flats.
I called the guys at VM and they told my where to make changes so VM would cut the arcs smooth with out the segments.
With this selection made VM outputs the I&J’s for hole pocketing.
Logged
Graham Waterworth
2,785
Re: Help!!!!!
Reply #4 on:
March 31, 2008, 06:02:13 PM »
Normally you would output without any options ticked, then you should get a single line of code for each move down in Z.
E.g.
G03 I-.25 Z-.05
G03 I-.25 Z-.10
Etc.
Graham.
Logged
TT350
113
Re: Help!!!!!
Reply #5 on:
March 31, 2008, 07:35:39 PM »
The hole is 1.0 why is the I-.25?
Chris
Logged
jallitt
44
Re: Help!!!!!
Reply #6 on:
April 01, 2008, 04:10:32 AM »
is it skipping steps in one axis in the G00's? If you turn off "use rapids" in the feedrate dialog in VM it'll do G01's at the selected feedrate instead. Have you checked your motor tuning to make sure it can still run at top speed in that axis?
Logged
TT350
113
Re: Help!!!!!
Reply #7 on:
April 01, 2008, 08:03:46 AM »
Yes it is skipping steps.
After it cut what you see in the board I checked the X Y zero
and the X was way out, over an inch.
Chris
Logged
TT350
113
Re: Help!!!!!
Reply #8 on:
April 01, 2008, 08:17:20 AM »
I don't think there's any G00's in the Hole pockting code.
Logged
Carnoustie, Scotland
Re: Help!!!!!
Reply #9 on:
April 01, 2008, 10:30:28 AM »
Is the X DRO out as well or is it just the axis?
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
