Hello Guest it is November 13, 2026, 10:01:17 AM
Author Topic: mach don't control the spindle switch  (Read 45853 times)
« on: March 26, 2008, 10:18:07 AM »
u can see the setings atached.
i tried a lpt tester program and the switch works on pin 8 so the problem is with the mach setings.
also tried lots of diffrent setings , i installed a diffrent version of mach.. nothing happens.
in the "diagnostics" tab the "output 1" is blinking red when i input "m3" command.
Re: mach don't control the spindle switch
« Reply #1 on: March 26, 2008, 11:47:53 AM »
What have you got in your motor tuning for the spindle?
Have you tested at the pin on the port with a volmeter?
What happens when you M4 in MDI?
« Reply #2 on: March 26, 2008, 12:47:38 PM »
1 i have nothing at the motor tuning for spindle, didn't realize i should change something there, i only want to switch the relay on/off
2 i tested with the voltmeter, it get 2.7 volts always m3/m4/m5 changes nothing.
3 nothing is happening.
the relay only switches with the lpt program.
another thing i just found, when running a gcode program (generated with sheetcam) it switches 2-3 times/second.
u told another guy on the forum to use a macro for switching a weldinng machine on/off... this is kind of the same thing..
tx for your patience.
« Reply #3 on: March 26, 2008, 01:13:53 PM »
Looks like you are using Relays and Step/Direction Motor Control.
I don't believe you use Relays with Step/Dir.
RC
« Last Edit: March 26, 2008, 01:19:49 PM by Overloaded »
« Reply #4 on: March 26, 2008, 01:21:51 PM »
the guy who made the driver board gave me the setings.. and 5-6 hours of online support .. but we couldn't switch the relay.. :(
 i will try and disable the motor control tomorow and see what happens but i'm pretty sure i've done that at some point
« Reply #5 on: March 26, 2008, 03:26:33 PM »
As RC says you have your relay connected but also you are using step and direction, If you are using step/Dir then it is treated just like an axis, ie you dont need relays.
What kind of spindle motor do you have, is it a servo/stepper?
« Reply #6 on: March 27, 2008, 05:24:28 AM »
i'm not using a spindle , i try to control the plasma torch on/off with that relay.
i tried with the motor controll unchecked and the spindle relays on.. nothing happens, tried the other way too.. relays off and motor control on still nothing.
if i leave the lpt tester program in background when runing a gcode in mach , the relay is switching on/off 2 times/sec but nothin with m3,m4 or m5 or the torch on/off button .
i installed a new version of mach.. still nothing.
« Reply #7 on: March 27, 2008, 07:18:39 AM »
Attach your xml file and we can have a look and see if we can figure out the problem.
« Reply #8 on: March 27, 2008, 08:04:37 AM »
i tried with a diffrent cnc program an it controls the switch ... but i like mach3 and allready bought a license
here's the xml
« Reply #9 on: March 27, 2008, 08:10:04 AM »
Your XML says "Demo Version".
Is your lic. file in your Mach3 folder?
May make a difference ? ? ?
RC
