Hello Guest it is October 28, 2026, 10:16:09 AM
Author Topic: help need with brains and modio feed pot  (Read 10699 times)
« on: March 21, 2008, 04:38:14 AM »
hello i using 3 analog pots on peter modio feed,rapid override,spindle override,
they all have steps eg on the feed  and spindle are 0,20,30,40,50,60,70,80,90,100,110%
rapid is 0 , 25,50,100%
feed is on analog 3, slave 1 i have work this bit out as address 8 ,config 1, serial set up etc
on the brains i can get the 0 -1024 bit aok
so how can i get this to set the steps up
one way i can see is
analog3 is less then eg20 the set dro to 0
analog3 is more then eg20 less then 120 set dro to %20
this will work but their is a lot of rungs to do, is their a formula to do it. i have gone thick and don't have a place to start from.
please help or some one post me some sort brain they have done so i have a start
thanks Adrian locker
Re: help need with brains and modio feed pot
« Reply #1 on: March 27, 2008, 01:15:17 AM »
Hi Adrian,
As you are not using a constant spacing between steps, i.e. 0, 25, 50,100 a formula would be difficult. It would be easier to just do a set of comparison rungs and be done with it.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
