Hello Guest it is November 01, 2026, 12:17:52 PM
Author Topic: Lazy Cam Inserting Z0.0000 instructions ruins job.  (Read 11314 times)
« on: March 13, 2008, 02:07:25 AM »
Hello All,
I have a simple dxf file of a rectangle, and i want to cut a groove into a piece of wood, I have set the layer to:
Rapid height: 35.00
Cut Start: 30.00
Cut Depth: 10.00
The tool is set to do 2mm per pass, so after 10 passes I should have my rectangular slot.
But Lazy Cam inserts a Z0.0000 instruction at the start of a straight cut, which apart from destroying the job, ruins the bits in the mill.
Does anyone know how to stop this??
Thanks.
Offline docltf
  •  354 354
Re: Lazy Cam Inserting Z0.0000 instructions ruins job.
« Reply #1 on: March 13, 2008, 12:53:04 PM »
try going this way when you set your tool in layers,make sure all layers are what you want.
Rapid height: 35.00 = tool above work
Cut Start: 00.00      = tool touching work
Cut Depth: -10.00   =  tool in work
bill
« Reply #2 on: March 14, 2008, 11:30:37 PM »
Thanks for the reply docltf I tried your way, and it worked fine.
However the first stage was cutting a jig in a piece of wood to hold the final job, the jig was cut, but then the job sits on top of the jig and I don't have the option of setting 0.000 as the point touching the work.
Surely there is a way to stop LazyCam inserting these random Z0.0000 instructions into the G-Code?
What is the point of these instructions??
Is there an option in LazyCam to change the point to something like the safe Z?
Cheers, Mark.
« Reply #3 on: March 14, 2008, 11:47:32 PM »
Hi All,
I've solved it!
For anyone else with a similar problem, you need to "Clean" the drawing in LazyCam to prevent it from inserting Z0.0000 instructions.
To the developers of LazyCam:  Is this a bug? Or is there a reason why these instructions are inserted?
Thanks all.
Mark.
