Hello Guest it is October 24, 2026, 12:43:09 PM
Author Topic: LazyCam G-Code  (Read 19077 times)
LazyCam G-Code
« on: March 12, 2008, 04:49:56 AM »
I get error message with G3 radius "center wrong". Solution?
  •  9,374 9,374
Re: LazyCam G-Code
« Reply #1 on: March 12, 2008, 06:39:20 AM »
I have used Lazy Cam 2.00.060 to create the G-Code from your DXF.  Running this code with Mach3 R1.84.000 I have no problems.
I attach the G-Code for you to try.
Good luck,
Re: LazyCam G-Code
« Reply #2 on: March 12, 2008, 09:56:06 AM »
Could be that your "I-J mode" is set opposite of what it should be. In Mach3, go to config tab>general config. I-J mode is listed in the middle of the page.
