Hello Guest it is October 28, 2026, 10:11:58 AM
Author Topic: Terminating a brain with "Execute Button Script"  (Read 16692 times)
Offline Greolt
  •  956 956
« on: March 05, 2008, 04:06:36 PM »
I am revisiting this idea where I wanted a brain to set a script going.
Poking around the brain editor I found "Execute Button Script" in the Button Press selections for Lobe Terminations.
How does this work? Does it work? How do I specify the button script to execute?
Thanks for any help, Greg
PS:  I have also asked this on the Yahoo group.
Re: Terminating a brain with "Execute Button Script"
« Reply #1 on: March 05, 2008, 06:17:35 PM »
I dont think Art got around to doing this function, before he left. It is an Art or Brian question..........
scott
« Reply #2 on: March 05, 2008, 08:23:31 PM »
 Since Art cleared that up, on the mach yahoo forum, you can use my "Run once" in the macro pump to set your macro. Macro 600 below can be what ever, or change to your macro number.
'macropump.m1s
i=GetUserDRO(1500)
If i=0 Then
SetTriggerMacro( 600 )
SetUserDRO(1500,1)
End If
If GetOEMLED(800) and i>0 then 'resets counter in a reset conditon
SetUserDRO(1500,0)
End If
'Scott
Offline Greolt
  •  956 956
« Reply #3 on: March 05, 2008, 09:06:29 PM »
G'day Scott
Yes I have a version of your macropump working. Thanks for that.
I did not follow Art's explanation.  And seems to me a different response from Brian.
When I spotted that "Execute Button Script" option my eyes lit up. :)
Sadly it seems it is not implemented.
Greg.
« Reply #4 on: March 06, 2008, 10:52:34 AM »
Greg,
   NOTE:!!!!!
The Macro pump ONLY sets up your "Set Trigger" ONCE when comming out of a Reset Condtion. After that, this code drops out and does not execute again until the next Reset.
But now that your Trigger is set for the Macro, anytime brian hits this button it will run your script. Macro pump ONLY sets your trigger once, Brian then handles all other events for this macro.
scott
« Reply #5 on: March 14, 2008, 10:14:21 AM »
Is there some documentation that explains Execute Button Script through brain?  I personally find the yahoo forum very hard to use. So I can not follow the discussion over there.
« Last Edit: March 14, 2008, 10:19:34 AM by SailFl »
