Hello Guest it is November 13, 2026, 09:23:58 PM
Author Topic: Z axis direction  (Read 29623 times)
Offline kak
  •  81 81
Z axis direction
« on: March 02, 2008, 10:24:09 AM »
Hello
I want to try to mill something for the first time, and have a little problem with Z axis.
My Z axis is homing in the positive direction, from -60mm(limit) to 0(home/limit).
If I want to miil something, I want the Z axis to move down to my table in the negativ direction, but the G code Z has a positiv value. When I start the program the first thing that happen is, the Z axis hits the home/limit switch.  Anybody know how to change the Z direction without messing the rest of the Z setup, like homing diretion ect.
Adam
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Z axis direction
« Reply #1 on: March 02, 2008, 12:19:08 PM »
If you touch the tool on the bed of the machine and press the zero Z Mach will datum up on that face. all your z moves are then up from the machine bed.
Graham.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: March 02, 2008, 02:50:29 PM »
Hi, Adam
If your Z axis shows Pos values going "up" to home, That is correct.
Your G-code Z values need to be Z-## in your Posted G-code.
If your using LazyCam, Layers Tab at Bottom Set cut depth to a negative value " -##", and click on "Set Layer" and or "Set All Layers".
Then Jog Z down to the top of your Part's top Surface and Zero Z Axis.
After you get your G-code stratined out, Your machine will show neg. cut's.
Hi, Gram
Haven't used your method, Can see that it will work Fine, Just it's Bottom's Up,  Instead of Top's Down.
Hope this Helps, Chip
Offline kak
  •  81 81
« Reply #3 on: March 02, 2008, 04:08:14 PM »
Thanks Chip, I will try that.  I wrote an "E" letter with LazyCam and want try to mill it.
What if I get a large 3D job with many Z movement - do I have to correct all the positiv values to negativ manualy?
Graham - do you mean I have to zero the Z Offset Coordination when the tool is touching my table?   Because I can`t zero the Machine Coords down there. Only the home switches can do that.
I`m confused her. What is the order?
1. I home all the axis
2. I put a piece of material I want to mill somewhere in the middle of my table
3. I move all the axis until all of them (my tool) touches my material ( Offset Coords)
4. Zero all axis(Offset coords)
5. Regenerate toolpath
6. ??? do I have to Home ?
Graham - when to zero the Z, touching the bed of my machine?
... and I can`t wait to push the Start button.
That what I call Offset Coords - is this what you call DRO?  Is it when there is no red ring around the Machine Coords button?
Adam
« Last Edit: March 02, 2008, 04:23:57 PM by kak »
« Reply #4 on: March 02, 2008, 04:24:53 PM »
What Graham is meaning is you home as normal, this sets the Machine Coordinates. You can then jog to any place you want and set a work offset zero by pressing the Zero axis button at the side of that axis DRO. When you do this the DRO will read Zero but if you press the Machine Coords button you will see that Mach has remembered the true position.
 So by Grahams method you are setting your table (or lowest part of material) to zero as an offset and as your code is all positive it will work fine. Its normal to have your code as zero for top surface of material and all cutting in the negative but some people like it the other way.
Offline kak
  •  81 81
« Reply #5 on: March 02, 2008, 04:47:46 PM »
Thanks Hood
The positiv Z value is only 0.1 unit, but i don´t have that thin material to mill in. If I use a piece of blue foam which is 1cm high, how do I move the tool to the top of it, if Z moves only 0.1 from the buttom?
Adam
« Reply #6 on: March 02, 2008, 04:57:09 PM »
Go to the top of your material and type 0.1 into the Z DRO and then press enter. Really though its best to get your code sorted for normal operation. If your CAM programme is outputting all positive values it should be possible to alter the post processor or a setting somewhere to make it say zero is the top.
Offline kak
  •  81 81
« Reply #7 on: March 03, 2008, 02:29:26 AM »
This is not easy. Much harder to understand than my foam cutter I`ve build for 6 years ago.
When I move my tool until it touches my material and zero the axis and regenerate toolpath, is that the position when I start the milling or do I have to home first?
Adam
  •  2,785 2,785
« Reply #8 on: March 03, 2008, 02:36:56 AM »
If you are still working Z plus.
Move to top of job
In Z axis DRO type 0.1 and press ENTER
Move away from job a safe amount ( 1" or 25mm)
if you are working Z minus.
Move to top of job.
Press Z axis zero button next to DRO.
Move away a safe distance
Run program with care.  Turn on single block and slow rapids down to a crawl.
Graham.
« Reply #9 on: March 03, 2008, 02:44:39 AM »
Adam
You need to home when everytime you start  Mach but thats all unless you crash and loose steps, then you need to home again.
