Hello Guest it is November 26, 2026, 06:58:28 AM
Author Topic: Programable buttons  (Read 12997 times)
Programable buttons
« on: March 01, 2008, 01:20:11 PM »
I posted last time
I Have 3 machined running Mach 3 and they all do this.  When pressing an external start button My spindle comes on as it is suppose to, but some times I get a momentary output on output #1 It lasts for maybe .5 seconds. If I cycle the maching using the on screen start button it never dose this. I have try ed changing the pin# and the output #, ran shielded wire to my start button, and it still dose it. Here is my G code program it is very simple
M3
X -00.000 Y00.00000 Z00.00000 F550.00
M11 P4  -----> this one too will blink on for just a .1 of a second this is my machine on
G1 X -00.010 Y00.00000 Z00.00000 F030.0
M11 P1   ------> This is the output, it turn on at the same time as the spindle and stays on .5 seconds then shuts off and then turns back on
G4 P00.34
G1 X -04.8000 Y00.00000 Z00.00000 F090.0
M10 P4
M10 P4
X -05.7000 Y00.00000 Z00.00000 F800.00
M11 P5
G4 P0.9
X -05.7500 Y00.00000 Z00.00000 F800.00
M11 P7
X -05.7600 Y00.00000 Z00.00000 F800.00
G4 P00.2
M10 P7
M10 P1
X -05.7650 Y00.00000 Z00.00000 F800.00
G4 P0.2
X -00.000 Y00.00000 Z00.00000 F800.00
M30
M30
My start button is on oem trigger #1 and set on active low..
I am using a simple brake out board and an amplification/printer port protection board,,
where have i gone wrong
thanks to all
Josh
Tryed all of what was in my last post with the same results.. My next thought is dose anbody know of a progrmable set of  buttons That I can set as a start button for mack3 ALT-R
Re: Programable buttons
« Reply #1 on: March 02, 2008, 05:05:48 AM »
Josh
Can you give me the macro that you have created for external start button?
Sanlee
« Reply #2 on: March 02, 2008, 06:05:38 AM »
Sanlee,,
I have my cycle start (code 1000 on OEM trigger 1) set on input pin 12.
Thanks for the reply
Josh
« Reply #3 on: March 05, 2008, 01:36:10 PM »
for anybody reading this post,, I installed a j-pac from http://www.ultimarc.com and ran my cycle start and stop through the j-pax and have not had one issue.
thanks
Josh
